i bought a banshee and it has some type of aftermarket bearing carrier and axle and it has some play in the bearings so i wnted to replace them and i can not figure out how to get the axle out i got the book out but its nothing like the factory set up it only has one big lock nut?? any help is appreciated thanks
Is it a honda style rear end or is it still a banshee bullshit setup? On the honda style round house bearing carrier you take the left wheel off, take the nut all the way off, remove the chain from the rear sprocket and take the sprocket boss off the axle then disconnect the rear brake caliper and slide the axle through to the right. then pull the axle carrier out through the left.
