MotulMonsta Posted May 10, 2004 Report Posted May 10, 2004 Higher psi in the front makes the tire stiffer, a stiff tire won't roll in on it's self when your charging hard and fast into the turn. You want that front to cut the terrain like a knife..not conform to it..yes you can feel more of the bumps running at 10 psi then 4..but 4 psi and you'll pop that tire off the rim in a hard corner. Try it out..pump that front tire up to 10 psi and run it fast into a sharp turn then drop the psi down to 4..you'll feel the diffrence. Quote
J..J. Posted May 11, 2004 Report Posted May 11, 2004 We ride mostly sandy trails, with some rocks here and there and river sand + mud. (Botswana) Hey Percy Good to see a fellow "African" on here. Where in Botswana are you from? Hockey, like the others said 20PSI is way high man... Quote
