what is a stock 2001's compression ratio?
what grade gas can i run? (midgrade, premium, etc)
what is the best oil and mix ratio to use?
any help is appreciated
Stock should be around 130psi.
I would recommend only running Premium, 91+ octane
Break-in: book says 24:1, 32:1 would be just fine on a stock bike. I've always mixed mine, even when stock at 40:1.
Hope this helps. And welcome to the HQ. B)
I just got my banshee a month ago. At first I ran 24:1 like the manual says but it made me foul 2 plugs. I thought I bought a lemon, but after I switched to 32:1 (4 ounces per gallon) it runs perfect.:headbang:
Does anyone know a website to buy Yamalube cheap?
your gunna get 100 different replies on which oil is better. I run amsoil series 2000 but any good oil will be just fine.
