It will only eat bearings if it gets in where it shouldn't be. If you have everything sealed, you will be fine.
Eat chains... nope. Been doing the dunes hard for 4 years, only on my 2nd chain.
What I do is put chain lube on at home and take it for a quick ride to fling off the excess then wire brush the chain to get any crud of the chain so its nice and clean. You want a well lubed chain but not drippin with lube or a bunch of sand will stick to it and thats not good. If you can't ride it to fling off excess before the sand then just brush and/or wipe it down good so its not a sand magnate and it wont wear on the chain or sprocket any more than usual.
The best thing I've ever found was when I used to mountain bike. Slick50 wouldn't get sand or dirt stuck in it, but WD40 was the WORST!!!! One ride in the sticks and I had to degrease that damn thing. The Slick50 worked wonders.
Personally I never wax or grease my chain.
Try the dry graphite spray lubricant. Works great and sand can't stick to it. I get mine at Napa.
  • 2 weeks later...
I have a two-seater Spyder on order. (rolling chassis) I was going to put a turbo 2.0 Subaru in it, but I totaled my wife's Tiburon two months ago (trying to drift in a front wheel drive car is hard!) and I am currently trying to see if I can mod the engine/chassis of the spyder to make it work. If I can figure out how to get 300 HP out of a Hyundai engine, I will ditch the Subaru idea and save myself $8000. I bought the car back from the insurance company for $400. They must have not known that there was 5 grand worth of rims/tires/sound system. The engine only has 1200 miles on it.
Well good luck with both projects and keep us posted on the progress, theis heat will end in a few months and then its GLAMIS time once again!
Right on Dune Demon! I hope to be ready by Thanksgiving weekend. Hope to see you there! :cheers:
