I sold my 2000 stock banshee ,witch was my first quad, for 2,100 cash, then the same day bought a 98' built shee for 2,100. It doesn't look like much now but it will stand stright up in 5th w/ out featherin the clutch!
Anywho, I turned the front wheels around for more width but the vavle stems get in the way when the wheel rotates :angry: ?? how can i put the valve steems on the other side of the wheel :wacko: ? This (hopfully) easy mod will add atleast 2" on each side.
pretty easy to do your gona have to take off the tire off the wheel and put valve stems in up side down then on the other side drill new holes and put valve stems in :)
I did this same thing on the rear of my shee and the stems do not hit. before you drill holes i would put lower profile stems in. plus, it looks better without stems on the outside and the would get broke off if you catch something on the outside of the rim. Hope this helps.
