nickxc Posted April 8, 2004 Report Posted April 8, 2004 I have a twist and I want a thumb. My friend has a thumb throttle off a warrior. I would just have to get a cable but Im not sure if they are the same. are they?????? any help is always appreciated thanks guys!!!! Quote
00BANSHEE Posted April 8, 2004 Report Posted April 8, 2004 I went out and checked out my wife's warrior and although the thumb throttle is shaped a little different I bet you could get it to work without any problems. Quote
evil Posted April 8, 2004 Report Posted April 8, 2004 no its not the same but you can make it work with the right cable. i forget the part number but it was made by terry cable. Quote
MADMOOSE Posted April 8, 2004 Report Posted April 8, 2004 ok my 250r has some twist i found a the wreakers and a cr80 cable....langhts perfect and it gets full use of carb...havent got it runnign to test it yet tho Quote
clint Posted April 9, 2004 Report Posted April 9, 2004 yes the warrior housing will work. you use the stock throttle cable.i broke my housing, and had to use a warrior one for a little while, works fine. Quote
