clint
Everything posted by clint
  1. 89 i just picked up CHEAP.
  2. direct methane injection!
  3. not a joke.my neighbors snowmobile was stolen also.chances are good that it is gone.
  4. stolen on april 4th from standish maine.it is blue and yellow, and has fmf fatties.any help would be great.thanks.
  5. yes the warrior housing will work. you use the stock throttle cable.i broke my housing, and had to use a warrior one for a little while, works fine.
  6. it seems like it takes forever to get it up to operating temp. too.
  7. i have a set on ebay right now.white buckets.going cheap. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMESSE%3AIT
  8. it already is in the 4th clip.anyone have some 27.5 pilots?
  9. slides are in the right way,and in sync.gas runs out of the exhaust pipes at idle until i pull the choke.it starts in 1 or 2 kicks cold with the choke.brand new top end about three hours on it.still real good compression.
  10. i have been playing with it, and now it seems to be ok as long as it is over an idle.if i try to let it idle it will drop a cylinder.pull the choke, and it will start firing again.i am running fatties, with k&n clamp on filters,stock pilots, 280 mains, undecided where the air screw should be so far.do you think i need bigger pilots?
  11. i just changed my carb bodies, used the same jets that were in my old carbs, now there is gas running out of the pipes. it is not a stuck float. only runs on one cylinder, gas poors out of the other, until i pull the choke out, then runs perfect.doesn't make any sense to me. i switched it back to my old carbs, and it does the same thing.any ideas would help, thanks.
  12. clint
    Pilot Jets
    they are only like $4 from magic racing, what do you need for a trade.
  13. clint
    Pilot Jets
    stock would be fine.thanks.
  14. clint
    Pilot Jets
    i need a set of pilot jets. anyone have some that they want to get rid of? let me know.the sooner the better.
  15. clint
    Cylinder Needed
    i have a complete top end.virgin cylinders, head, ported reed cages, stock intake with cross over tube, and a set of carbs with throttle cable and thumb throttle.might have the pistons too, can't remember if they are there or not.make a reasonable offer, or they will be on ebay pretty quick.
  16. more added
  17. clint
    Oil Dip Stick
    i should have one. i will check in the morning.
  18. clint
    Swingarm Part
    i have three of them, let me know if you still need one.
  19. new stuff added.......check it out.
  20. i have a set of front shocks,with white springs.sell for 75 plus shipping.
  21. did you get the tie rod yet?how did it work out?
  22. clint
    Need A Set Of Carbs
    banshee370... do they have the tors removal kit? or atleast the caps?let me know just in case.
  23. could be the voltage regulator.
  24. i have some stuff on ebay, more going on pretty quick. http://cgi6.ebay.com/ebaymotors/ws/eBayISA...&sort=3&rows=50
