Probably just the outside conditions. Humidity and air temp can play a big factor on carb'ed engines. One day it's great, then a front moves through and the humidity goes up and it drops 5 or 10 degrees and that can cause you to maybe need to kick it a few extra times due to the slight richening of the mixture.
Don't worry if it's running good.
