I would like to now if my kenth carbs are prejeted for pipes and K&n air filter?
And  does any one know what the stock jetting is on kenth carbs 30mm
I've never heard of kenth carbs. Never assume any carb is pre-jetted. Every machine needs a little different jetting than the other.
your going to need a main jet in the 140-170 range. id start out in the 150s-160s and see how the plugs look. and size 50 pilots should do it. and its keihin.
