Amstaff Posted March 28, 2004 Report Posted March 28, 2004 got a odd sound comein from the shee cant tell where its comein from it sounds like by the reeds or case and it sounds kinda like a fuoset with low water presser you know the kind with a screen on them but it seams to run just fine compression on both sides are 140 just rebuilt the top end last week so my question is do reeds or water impellers make some kinda sound when they go bad? reeeds looked good when i put them back in thanx in advance for the info Quote
MotulMonsta Posted March 28, 2004 Report Posted March 28, 2004 I'm thinkin' air leak. Bad water pump will make more of a buzzing noise and gets louder with rpms. You can put a srewdriver on the pump and get a good listen just to make shure. Dead give away would overheating. Quote
