Stomp77 Posted March 27, 2004 Report Posted March 27, 2004 hi, my banshee has the extra wires coming off of the CDI. its a green wire with a yellow stripe. it runs to a connector together with a black ground wire. right past the connector they are cut and capped!!! i did not do this shee came this way. My stator tests good, i replaced the coil, and my haynes manual does not show those wires or where they are supposed to go, does anyone know where they go to stock? can the green yellow wire not being connected stop me from getting spark? cause i have none? thanks! Quote
Stomp77 Posted March 27, 2004 Author Report Posted March 27, 2004 Could they (green/yellow) (black) wires be to the parking brake? if so, they should be "open" right? My stator tests perfect and it has good voltage coming out. The CDI shows voltage coming out but that supposedly doesn't mean anything. any wiring gurus out have a clue?? i just replaced the coil and the stator tests good, so that just leaves the cdi i guess. gonna get one on monday from a local 4-wheeler junk yard and find out.... Quote
