svtkid78 Posted March 24, 2004 Report Posted March 24, 2004 Shee is bogging down about 1/4 throttle. reacts good from 1/2 on. it'll sometimes give a good pop then go. plugs are a tannish coler. What ya think pilot to rich or maybe just air screws? Quote
svtkid78 Posted March 24, 2004 Author Report Posted March 24, 2004 just tried taking off air box lid didn't help air screws 2 turns out, when creeping it feels like right side not firing as much as left side. it is firing but alot more coming out of left exhaust pipe. hmmmmmm Quote
sredish Posted March 24, 2004 Report Posted March 24, 2004 what pilot size are you running, what pos. is the needle in? what kind of pipes etc? Quote
svtkid78 Posted March 24, 2004 Author Report Posted March 24, 2004 not sure the pilot it's been the same since mods were put on i'll let you know that. needle is 2nd from the top, running ptr mids, wicked motorsports cool head, v-force reeds, k@n w/ airbox - the snorkel. what you think pilot should be around and it just started to happen maybe carbs out of sync gotta get tors elim. kit Quote
sredish Posted March 24, 2004 Report Posted March 24, 2004 27.5 pilot will probably work good, though your needle needs to be richer than that. Try the 4th position, the 3rd is minimum with pipes. Up to 1/4 and 1/2 is a lot needle. The air screw won't really affect it. Try the needle and see if that helps, you could be lean and just need more fuel. Quote
Banchetta Posted March 25, 2004 Report Posted March 25, 2004 Raise your needles all the way up.. I run mine in the 5th clip from the blunt end, stock pilots, adjust air screws to .5 turn from seated and see how it likes that...Also, take the snorkel off.... Quote
svtkid78 Posted March 25, 2004 Author Report Posted March 25, 2004 clip is already at top, and snorkel is removed. right now its at 2 turns out ill adjust and get back tomorrow. thanks Quote
sredish Posted March 25, 2004 Report Posted March 25, 2004 clip is already at top just checking with you here, but AWAY from the blunt end is how you should be moving it, not towards the blunt end. The closer you move the clip to the sharp end is richer. You should be putting it in the 4th clip AWAY from the blunt end, or as Banchetta recommends, trying the 5th clip AWAY from the blunt end. Sorry if that's what your doing, but what you said sounds fishy. Quote
Banchetta Posted March 28, 2004 Report Posted March 28, 2004 Agreed, moving the clip down will raise the needle......4th or 5th clip from the blunt end so the clip will be moved towards the taper.... so when you put the needle back into the slide the needle will be higher inside the slide.... Quote
