I took all the clutch plates out and put a flat head screwdriver through one of the fingers on the basket and wedged it in one of the notches on the hub. I know I'll catch hell for telling you this, but I didn't have an impact handy and it took me a couple hours and a few failed attempts before resorting to the trusty screwstick. I was kicking myself in the ass for not trying it sooner. Be careful.
I bought an impact wrench for 50$ new and was the best tool purchase i've ever made :clap: removing those hard to get off nuts like that and the flywheel are SO easy with an impact it will make your head spin.
i tried the screw driver method before i posted this thread. hehe. but no luck. i went to try the impact gun and couldnt find a 1 1/4" socket, only a wrench. so ill go buy the socket and hope it will work, thanks for your help..........
I bolt a old friction plate and steel plate together,and then hit the nut with a impact gun.Works great  B) .
That is the best holding tool. It even works for re-torquing the nut. Just put it in gear and hold the brake.... then put in the clutch and steel that is bolted together and torquer down.
