51222 Posted March 15, 2004 Report Posted March 15, 2004 hey my kick startar is empty its like when i kick it it goes down without any engadgment in the gears so what do u think the problem is i wana listen to some opinions before i open up the case... Quote
frocashmoney24 Posted March 15, 2004 Report Posted March 15, 2004 well, you coulda fried ur rings, making it seem like it has no compression, or....the spring mighta popped off, take a compression tester and if u have good compression pop off the clutch side cover and see if the spring is still on there, id suggest getting a clymer manual Quote
scotts96fast Posted March 15, 2004 Report Posted March 15, 2004 well, you coulda fried ur rings, making it seem like it has no compression, or....the spring mighta popped off, take a compression tester and if u have good compression pop off the clutch side cover and see if the spring is still on there, id suggest getting a clymer manual what he said.... Quote
Nighty Posted March 15, 2004 Report Posted March 15, 2004 Could be what the guys above said. But from what you are saying it sounds like your engine is not turning over at all is it? might be the sprocket behind your clutch basket. of if you're lucky some other sprocket that broke. how did this happen? anything done special lately? Quote
51222 Posted March 16, 2004 Author Report Posted March 16, 2004 well i guess when i will have the time i will open the cover and see what is the problem...thanx for the help Quote
SICK BOY Posted March 16, 2004 Report Posted March 16, 2004 If you don't hear movement from the motor,and the kicker just goes down with no effort it's probley the spring. Quote
