CrashFireBanshee Posted March 12, 2004 Report Posted March 12, 2004 I have a ricky stator adjustible timing plate and I was wondering what it would be safe to advance it to. Stock motor with fmf fatty pipes. Also if I advance the timing do I need to rejet? I am running 91 octane fuel also. What benifits does advancing the timing give you? Quote
Wallrat Posted March 12, 2004 Report Posted March 12, 2004 Most people stick with +4 degrees. I've got a degree key that advances it 3 or 4 degrees. It feels like the engine has more balls is the best way to describe it. And no you don't have to rejet. What altitude are you at? Quote
CrashFireBanshee Posted March 12, 2004 Author Report Posted March 12, 2004 I am around 1350 ft. but I also run at 2300 ft and would like to make it glamis soon which is 330 ft. Quote
CrashFireBanshee Posted March 12, 2004 Author Report Posted March 12, 2004 What jetting do you suggest for the fatty pipes. I just put them on. I have played with the premix ratio some to compensate. I had a dynoport 2-1 pipe on it before but I have no idea what my jetting is. Guess I need to just rip it apart and learn how to jet. Quote
909 Posted March 12, 2004 Report Posted March 12, 2004 You can go up to 4 degrees without worrying about detonation on pump fuel. Any more and you'll want to run 50% race mix. 7 degrees would be max with race gas and completely unnecessary with your mods. Not too sure on jetting for the 2 into 1 pipes but for tommeys and fmfs @ glamis, people are running 280 mains and the correct toomey needle. Dynojet has the right needles in their jetting kit. I would strongly suggest you lay out the $65 for this kit and be damn close. The enemy for you right now is if you're running the tock needle. The center of it is fatter than the dyno jet/toomey which will run you lean in the mid range. Quote
fixitrod Posted March 12, 2004 Report Posted March 12, 2004 When I had my fatties on a pretty stock motor I ran 340 mains, 25 pilots (stock), and the needle lowered one position. Fatties seem to like a leaner needle. That was with no air lid and a k&n filter and stock carbs and 500' elevation in Indiana. Humid air here. Quote
sredish Posted March 12, 2004 Report Posted March 12, 2004 and the needle lowered one position. Fatties seem to like a leaner needle. That was with no air lid and a k&n filter and stock carbs and 500' elevation in Indiana. Humid air here. I run my needle in the 4th position, but that is probably due to the single carb setup. Quote
ledofthezep Posted March 12, 2004 Report Posted March 12, 2004 I'm now running the same stator myself. I advanced the timing +4...no regrets. Now shee has absolutely no hesitation from idle to WOT. Give me a chub just think'n about it. Quote
scotts96fast Posted March 12, 2004 Report Posted March 12, 2004 With all the different setups that are out here.Has anyone had problems running +4 timing on pump gas?I've been tossing it around to run +2 or+4 with my set-up....I have 150 PSI from what I heard porting can be a factor also. Quote
