"thenewguy" Posted March 9, 2004 Report Posted March 9, 2004 i have cleaned the carbs, new gas, its got spqrk, its got air, its got compression. its just not running. i dont under stand. if you guys could refer to my post in the jetting forum and maybe post what you think might be the problem i would appreciate it. and the reeds look like there ok. i dont know what to do with these carbs, its just not workin. Quote
frocashmoney24 Posted March 9, 2004 Report Posted March 9, 2004 are these stock are aftermarket, choke tubes connected? boostbottle or cross overtube connected?, slides going up in sync? Quote
supergrzz Posted March 9, 2004 Report Posted March 9, 2004 Check and make sure you have the right bowl on the right side. This happend to me. Look at both bowls real close and you will see a brass ball down at the bottom of the inside. This bowl goes on the choke side carb. Also make sure you have the slides in correctly. You need to be able to see the intake side of your carbs to make sure they come all the way down. I have done that also. I try to get things done to fast. LOL The bowl thing was the one that got me good. This is for stock carbs. Supergrzz Quote
"thenewguy" Posted March 10, 2004 Author Report Posted March 10, 2004 another float bowl problem. lol. started on the 6th kick. its not pulling the the right any more either. i swear the guy i bought it from is a idiot. the on the lower part of the axil where it bults to the swing arm, there was no nut on that bult and the bolt was half hanging out. lol at least it starts now. now my next fixing will be to the clutch. i think its just worn or needs some tightening. thanks for your help guys. Quote
