what should i clean th stator with? a little alchahol and a soft brush? its got crud on it from moisture build up (frezzing and thawing in the unheated garage) is there any good or recommended way to lightly clean it?
After you get it clean,put a coat of liquid electrical tape on it (not on the pick up's).This will protect it,cover any bare spot's,and make the next cleaning easier.Fro is right,electric motor cleaner in a spray can works great.
Like frocashmoney24 said, use some electrical cleaner. Personally I think the best stuff to use is CRC lectra clean which can be found at most hardware stores (like HomeDepot in the electrical Dept). It blows the crud out, and evaporates quickly taking any oily residue with it.
