"thenewguy" Posted March 6, 2004 Report Posted March 6, 2004 the other day i looked at my pistons through the spark plug hole and i saw black plack on my right piston. i was wondering if there was a way to take it out and clean it with rubbing alchol or some thing. i want to use the same piston and ring because i dont have the money right now to buy new ones. is this possable? and is there a link that you cant point me in the right direction or could you explain it if its simple. thanks my bike is currently not starting, and i would like to fix it soon. thanks Quote
frocashmoney24 Posted March 6, 2004 Report Posted March 6, 2004 its normal, its carbon fimiment from ur oil ur mixing with your gas, no need for a tear down or anything, some oils do it worse then others Quote
