Is there any benefits in buying a high output stator other than running bigger lights? I need a new stator and trying to decide between a ricky stator stock replecement and a ricky stator high output.
Go with the Ricky Stator 200watt,its only 160.00,stock lights are 35w,most aftermarket lights are 55w. He also has the lazer lights that mount on handle bars,I have this set-up,this set-up is great,lights turn with the handle bars no spinning the bike around to see and they are higher up,you can see the bottoms of whoops better at higher speeds.There are other good setups as well-this one works great for me.
