l0wrider Posted February 15, 2004 Report Posted February 15, 2004 what kind of paint should i use to airbrush my shee???? is there any certain type??? then after im done, should i put a coat of gloss on top????????? Quote
banshee370 Posted February 16, 2004 Report Posted February 16, 2004 what kind of paint should i use to airbrush my shee???? is there any certain type??? then after im done, should i put a coat of gloss on top????????? urethanes preferably.... (basecoat-clearcoat) Yes you will want to apply 2 coats of a urethane clear once your done w/ the artwork. I hope you dont plan on airbrushing directly over the plastic... You will need to prep the plastic for paint and then apply a ground coat (color of your choice) You then want to do your artwork over the groundcoat and then clear... Its a long drawn out process and if you skips steps you will end up w/ a mess Good luck Quote
l0wrider Posted February 16, 2004 Author Report Posted February 16, 2004 thanks for the info. i was basically gonna do just one color anyway(maybe wit some flames). But i was either gonna do like a black paint, with a gold flake(sparkle- pretty girly term for it). Quote
