Airbrush
l0wrider
what kind of paint should i use to airbrush my shee???? is there any certain type??? then after im done, should i put a coat of gloss on top?????????
urethanes preferably.... (basecoat-clearcoat)
Yes you will want to apply 2 coats of a urethane clear once your done w/ the artwork. I hope you dont plan on airbrushing directly over the plastic... You will need to prep the plastic for paint and then apply a ground coat (color of your choice) You then want to do your artwork over the groundcoat and then clear...
Its a long drawn out process and if you skips steps you will end up w/ a mess
Good luck
