cdw Posted February 12, 2004 Report Posted February 12, 2004 I run a barnett dirt digger. It was new last year and its starting to slip already, not much but it is starting to. I also run the right oil, incase your wondering. What would be a better clutch or clutch assembly that would grab better and last longer? Quote
ledofthezep Posted February 12, 2004 Report Posted February 12, 2004 That's the 1st time I've heard of anyone having problems with a dirt digger. Did you put the o-rings back in when you installed it?...should be left out & you may have. I dunno... I hear the cheap tusk kits work nicely,...you could get 2 kits for the price of 1 dirt digger too. Just a thought. Hinson makes good clutches kits also, my g/f's dad has been running a hinson for over 5 years now & it's still working great. Quote
Proquad101 Posted February 12, 2004 Report Posted February 12, 2004 The only clutch that I have ever had good results from is the stock yamaha clutch with the 3 fzr 600 springs. Everybody I race with uses the same set-up. Quote
