can i buy a 95-2004 frame and put my 87 engine in it? wHat else will fit? Swingarm? Plastic? Seat? will everything bolt up besides the a Arms? my 87 frame is bent and id likr to go to the newer style frame.
I have a mint 99 frame and a-arms if your interested...
Pics can be seen at www.roostfest.com/4sale.htm
There is a difference in the swingarm/carrier but nothing that would matter if you were planning on using the older swingarm/carrier together. (the difference is the mounting bolts and connecting tubes for the carrier) The older banshee's use 4 bolts to hold the carrier and the newer ones use 2 long bolts that go all the way through. The newer bikes also had a small running board attached to the pegs and subframe. (also not an issue)
Other than that they only changed the harness/plugs on the newer bikes.
