I noticed oil leaking from my motor, slowly. I thought it was the drain plug, but to my surprise there was a small crack about 1 inch long. It is located about an inch away from the drain plug. Can this be fixed my simply welding it, or do I need to go another route? The crack is not wide open, very small, but I have never dealt with anything like this. I guess that is what you get when you use UPS.
Thanks,
Kevin
p.s. It is a 2000 Banshee
Hey Kevin yea it can be fixed by being welded, but you will have to take it to someone that has a TIG welder. if you cant find someone with a TIG welder then maybe try some JBweld. but don't let anyone weld on it unless they have a TIG because any other method of welding it will destroy it.
