YamahaRider103 Posted January 31, 2004 Report Posted January 31, 2004 does any one no what i have to do to make my 95 banshee key less so all i would have to use is a kill switch Quote
sredish Posted January 31, 2004 Report Posted January 31, 2004 When I changed over to my T2 bars, I used the Tag oversize clamps and removed my key switch. I used the two wires from the key switch and wired them to the kill switch, one wire to each side, doesn't matter which, just so the circuit is broken. I now have my kill switch or the on/off switch with the light switch. I don't remember the wire colors, just use the wires and the key switch and reroute them over to the bar where you want the tether and connect them. Quote
YamahaRider103 Posted February 1, 2004 Author Report Posted February 1, 2004 does any one no how to make it so my pro design kill switch acts as the key and the kill switch under the lights switch. so when im riding and want to turn off the shee i can pull the kill switch, instead of using the stock on-off Quote
sredish Posted February 1, 2004 Report Posted February 1, 2004 wiring it like I mentioned will allow you to use the pd kill as the switch. On my bike, if I remove the tether, the bike can't be started. I also have the luxury of just reaching over and flipping the off switch so I don't have to pull the tether everytime I want to turn it off. Remember on the stock banshee, you can turn it off with the switch (under the lights) or the key. Simply connect the wires from the key switch to the wires from the kill switch, and there you go. If you don't want the switch under the lights just remove it and connect the two wires on that switch. Quote
