I have a stock 03 banshee with Delta 2s and Paul Turner K&N.. I would like to put it on alcohol. i need to know if it would be worth my time and money and how would i go about doing it, maybe having my stock carbs machined or buy aftermarket carbs to put them on alcohol.. I do a lot of duning, so that is the riding i will be doing. Any thoughts or opions would be greatly appreated.
You can put it on alcohol. But you need to know WTF you are doing. Screaminshee put his bike on alcohol with stock porting and was turning some wicked times at the strip. I would recommend that you get it ported first and see how you like that.... Or, do both. Port it AND put it on alcohol...
If you want it for dragging, go for it. If you want it for duning, then you might want to rethink it. You will burn about twice as much fuel with Methanol. That will cut your dune rides in half.
At Glamis I wouldn't be able to ride too far on methanol!
