what are the best carbs to get for the banshee that are bigger....ne info is gratly apretiated
I would recommend Trinity's CV 35mm Keihen (pwk) single carb kit is the only way to go. I've tried the 28mm and 30mm pwk's. This setup is a 1 minute or less jetting change, no synchronizing, no excess crap. The carb area is ten times easier to clean and no longer a rat's nest. It looks much more finished. The throttle is a tad looser, since your not pulling two slides. Oh, don't let me forget the power. This setup gives you more power than the other setup, in my opinion. The midrange pull through top is wicked. On dual carbs, air is pulled through the carb for a split second and then stops. With the CV kit, air is pulled through the carb constantly and the cylinders will see more air in my opinon. Here's what the kit looks like.
Link to Trinity's CV kit.
I'm sure whatever you'll find will work great, its just a matter of opinion. I like simplicity.
