screamin'twin Posted January 28, 2004 Report Posted January 28, 2004 im putting pc's on my shee here is everything that is on it now carbon fiber reeds, pro design intake & filter, no airbox lid, vented box, cool head w/22cc, prox pist. .10 over, port & polish im at about 1800 feet elevation im going to be jetting it for 50's and 60 degrees range for the spring, then again rejetting for the summer 70's and high 80's. i was thinking 310 main for the spring and 300 main for summer, 2 sizes up on pilots, and needle clip stock position??? what about the air screws?? i dont want to f*ck this up so any help would be really good!!!! Quote
Banchetta Posted January 28, 2004 Report Posted January 28, 2004 This is a guestimate to get you close....I'd start w/ 350 mains, 30 pilots, stock needle clip or 4th from the blunt end...let us know what the final results are.. Quote
spoin39 Posted January 28, 2004 Report Posted January 28, 2004 I agree with banchetta except for the 30 pilot, I would start at 27.5 w/airscrew 1.5-2 turns out. If the response off the bottom isn't good go in on the screws, if it gets better the more in you go then try a 30. Quote
