i bought this mclaren F1 polish, its good for removing crap also if u used a cheap polish and dulled them down, it will rub it off ... its quite good but that is the best thing to use on the plastics for geting that mirror shine ? <_<
Depending on how dull they are I use
armoral tire foam spray it on let it foam up
and just wipe it down don't wipe off just
enough to make it an even coat and let it dry.
Bouns if you ride a lot in hot weather it will also
keep your plastics protected so they don't get dried out
and crack easy when you crash also will remove stains in the plastics
