:( i just rejetted my quad and i was all set to go riding it started up, but when i went to take off it liek bogged then stalled, and it wount start unless the choke is on, it is warm but it still bogs, it has to be in the hihg revs and it is fine, but at low revs its horrrible i was to play with the gas so it doesnt stall why is this, and before when i had the old jets it and it was way lean it didnt do this
So how did you rejet? What jets did you change?
Your problem should be in the pilots and the needles.
Did you change anything there?
If its "bogging" could be rich..........then again I could be wrong
