frocashmoney24 Posted January 13, 2004 Report Posted January 13, 2004 how much compression do you run on your quad, i was looknig at 21 domes and its not gonna raise my compression much so i wanted to know what i could go with while still running pump gas Quote
ledofthezep Posted January 13, 2004 Report Posted January 13, 2004 My head's milled .030 & I'm at 150lbs on each cyl. Quote
shortys racing Posted January 13, 2004 Report Posted January 13, 2004 how much compression do you run on your quad, i was looknig at 21 domes and its not gonna raise my compression much so i wanted to know what i could go with while still running pump gas 20cc domes would be the same as a shaved head .030.....about 10lbs. per cc size. That would be ok for pump gas, but you should run super. not regular!! Quote
frocashmoney24 Posted January 14, 2004 Author Report Posted January 14, 2004 oh i have a mild port, 2-1 dynoport pipe, 2-1 trinity setup with 25 carb, trued and welded crank, fresh top end, would that effect it much Quote
