Im-Loving-It 69 Posted January 12, 2004 Report Posted January 12, 2004 I just put 300 mains-stock pilots-and the dame thing is hard to get started unless it warmed up please help Quote
Klotz Posted January 12, 2004 Report Posted January 12, 2004 how cold is it...where your at..mine is very hard to start to...unless its warmed up...give it primer kicks...then try... shane Quote
ledofthezep Posted January 12, 2004 Report Posted January 12, 2004 What are your mods?...why'd ya go to 300's? I've never had starting issues...if so I just turn the key off, hold the throttle wide open, kick it about 3 times, turn the key back on, choke it, & shee'll usually start up 1st or 2nd kick. Quote
Banchetta Posted January 12, 2004 Report Posted January 12, 2004 Certain pipes require larger pilots and will start hard w/ stock pilots....Also, is there a chance that the carb bowls got swapped?? The choke carb has a different bowl for the choke to work then the other carb.... Quote
Im-Loving-It 69 Posted January 13, 2004 Author Report Posted January 13, 2004 Im new to HQ i would like to know how i tell you my mods on the bottom of my in put? Quote
Wallrat Posted January 14, 2004 Report Posted January 14, 2004 Go to 'My Controls' and change your signature. Quote
budlightshee Posted January 15, 2004 Report Posted January 15, 2004 i agree with banchetta, i had the same problem iafter checking everything and going crazy it was my bowls switched and also my floats needed to be adj. Quote
Banchetta Posted January 15, 2004 Report Posted January 15, 2004 Im new to HQ i would like to know how i tell you my mods on the bottom of my in put? Pipes?? Quote
Im-Loving-It 69 Posted January 16, 2004 Author Report Posted January 16, 2004 No i found out that my front moter mount was broke and the bolts were broke of also!! MUST BE TO MUCH POWER!!!! Quote
