dirttrack25 Posted January 12, 2004 Report Posted January 12, 2004 alright well someone put in a post that u could disable tors by unhooking the lil black brain box so i did and also said u could just clip all the useless wires that goto the tors off so i did that now im not sure if its that or not but it ran b4 i did it so did i f*ck up or could it be something else Quote
FORMULASPEED Posted January 12, 2004 Report Posted January 12, 2004 there is a black wire with yellow stipe and a black wire twist them together. the wires are parrell together. up in the front look at 1 of the plugs you cut off for referance. hope this helps Quote
dirttrack25 Posted January 12, 2004 Author Report Posted January 12, 2004 the wires that would go into the brain or the wires that go upto the throttle..and thank you....if it works when i go try in a minute Quote
Banchetta Posted January 12, 2004 Report Posted January 12, 2004 I just unplug the brain, brake switch on the handlebars, and the carb tops....I never twisted or cut anything...Just unplug them.. Quote
fixitrod Posted January 12, 2004 Report Posted January 12, 2004 I just unplug the brain, brake switch on the handlebars, and the carb tops....I never twisted or cut anything...Just unplug them.. Me either. I cut the plugs off to and didn't have any trouble. You must have cut or disconnected something not related with the tors. Were you working on anything else? Carbs maybe. Quote
boonman Posted January 12, 2004 Report Posted January 12, 2004 You have cut an ignition wire. You need to find it, and hook it back up. Or, you cut the ignition wires going to the key switch and didn't re-connect them.... Quote
dirttrack25 Posted January 12, 2004 Author Report Posted January 12, 2004 i was working with the carbs too but i cant think what i would have done but its getting spark so i dont think its ignition Quote
fixitrod Posted January 13, 2004 Report Posted January 13, 2004 Check the simple stuff like the tube is between the carbs for the choke circuit. Check and make sure you didn't bind the throttle cable at the Y . Gas is on If you took the slides out, make sure you put them in the right carb. Quote
Banchetta Posted January 13, 2004 Report Posted January 13, 2004 You missed one Rod, make sure both kill switches are on.... Dirttrack25, nice avatar!!! Quote
dirttrack25 Posted January 13, 2004 Author Report Posted January 13, 2004 alright guys i got it runnin now...think it mighta just been flooded now if i could just get it to idle right and thanks banchetta and everyone who helped Quote
boonman Posted January 13, 2004 Report Posted January 13, 2004 Did you install the idle kit with the TORS removal kit? It is needed to make the bike idle... Quote
dirttrack25 Posted January 13, 2004 Author Report Posted January 13, 2004 no i didnt get new carb tops or anything i just did away with it electrically Quote
boonman Posted January 14, 2004 Report Posted January 14, 2004 You should spend the $50 and get the removal kit. You will thank yourself later.... Quote
