I'm sick of buying race gas so I'm thinking about throwing in 21cc domes and selling the 19's. Will the bike be noticably different? Right now I'm beating everyone, all I have are these domes the head and a pipe.
Somewhere around here sells it for like $200 a drum around 3.50 a gallon, there is a couple of other places i havent called yet either. AV runs 2.00 a gallon at the local air port.
usually if you got o different race gas cmpanies websites it iwll give youa ist of dif distributors in your area usually searchable with your zip code
it might be an hour or 2 drive to get a 55 but i think its worth it in the long run
oh and list of dif race gas ompnies might be handy
torco
vp race fuels
sunoco
klotz
i am sure some of the guys can think of others
klotz evan sells an additive that they claim will turn 93 fromt eh pump into 103
it comes in a 1 gallon container and you add it to 9 gals of 93
not sure just how good it works though
Shouldn't be any reason why you need to chang domes to run pump gas.19cc domes isn't that much compression.You will only have to change the jet.You will not gain anything by going to 21cc domes.You will only lose toruqe.
