Aesthetics Posted February 15, 2024 Report Posted February 15, 2024 Banshee won’t start, has compression, spark and I cleaned out the carbs. The timing is correct also and the gap. If I put fuel through the intake it’ll idle for a few. So I know I have a fuel issue. The float bowls are correctly set in height. Maybe incorrect jetting? Also it is bored out to 400cc. Quote
JerzOutlaw350 Posted February 15, 2024 Report Posted February 15, 2024 (edited) We need more info about type of carbs you are running and what jets you have currently in the carbs? (mains & pilots) Did you see if you are getting fuel from the tank to the carbs? Edited February 15, 2024 by JerzOutlaw350 Quote
Aesthetics Posted February 17, 2024 Author Report Posted February 17, 2024 (edited) On 2/14/2024 at 7:35 PM, JerzOutlaw350 said: We need more info about type of carbs you are running and what jets you have currently in the carbs? (mains & pilots) Did you see if you are getting fuel from the tank to the carbs? Hey so the reason the banshee isn’t starting is due to the previous owner having stroked out pistons instead of regular ones. Had nothing to do with jetting at all. Have to now purchase 66mm pistons. Was literally getting no compression. Edited February 17, 2024 by Aesthetics Quote
