bansheelover Posted December 29, 2003 Report Share Posted December 29, 2003 i was runnin my shee today and i noticed the right cylinder was not firing very well at idle.. when i revved it up.. it would run normally.. so my question is ...... is this a pilot jet problem?? thats what some ppl have been tellin me also can having a noss head and a pipe kit without having the timing advanced cause engine problems?? thanks again Matt Quote Link to comment Share on other sites More sharing options...
Meat Posted December 29, 2003 Report Share Posted December 29, 2003 Matt, put two brand new spark plugs in er and make sure they're gapped between .028 and .031, also make sure the little screw on caps ontop of the plugs are screwed on tight. See if this fixes your problem. If not, rip off the carbs and clean em up, inspect the jets making sure they're tight. Dont strip em tho, they're brass and strip easily. It might be a good idea to check your reeds while you have the carbs off. Quote Link to comment Share on other sites More sharing options...
