dmax104 Posted December 9, 2022 Report Posted December 9, 2022 Fresh motor. Only runs one cylinder 4 mil 65.00 ported and coolhead 24cc domes. Stock carbs tors delete. 27.5 pilot 330 main at the moment. all electrical test fine and swapped with another bike. after the rebuild it will only run one cylinder until revving up then the other will fire besides first start. Still fires first kick. after numerous parts swapping and jets I have narrowed the issue down to the Reed cage. Flip flopped the reeds and bam the issue switched cylinders. These vforce 4 don’t even have a full tank of fuel thru them. Possible bad set? currently waiting for a stock set to try out. Quote
dmax104 Posted December 15, 2022 Author Report Posted December 15, 2022 19 hours ago, silversmg45 said: Chinese knock offs? No they are legit. got it running right. Tore the reeds apart and thoroughly inspected and cleaned. Had residue in places couldn’t see from when previous meltdown Quote
