first off merry christmas and happy chanuach sorry if i spelt it wrong. any way i got a trailtech speedo and i have no clue how to install it. i think i have to take off the hub but idunno so if you could jus help me out. thank you
vinny
when you find out let me knowi ve been thinkin bout investing in 1. but i dont even know wher to fin the whole kit. i look in like rockymountan and it only sells everyhitng but the speedo...
I installed mine without too much trouble and I like it alot. IIRC the directions were pretty good. Did your kit come with them?
I'm not sure if I remember this correctly but yes you take the hub off. The magnetic bolt replaces one of the bolts in the rotor. You have to drill a hole in the dust cover for the pick-up. This is all from memory, I could be wrong. I'm going out to tinker in a minute and I'll take a closer look at how I did it.
One other thing I just remembered. That funky bracket with 3 holes drilled in it can be thrown out. It's really only necessary on 87-89's or so.
o ok that bracket was throwin me off alot. i sill jus need to know how to get this hb off then im ok
and also my magent fell out will rubber cement work to hold it in
thank you
vinny
