Qliphoth Posted June 15, 2022 Report Posted June 15, 2022 (edited) hi hello! i need a little assistance. i would like to know, how to change that one big Chain Roller/Guide seen on the picture below. my Shee makes plenty of noise on the move somewhere in the chain area and i suspect this big Roller, because it's quite lose, wiggles and sometimes the roller is not in line with the chain track, resulting in nasty rattle noises when the chain goes over it. there's a bolt that leads through the roller and even directly through the swingarm. is there a way to partly remove that bolt without dismounting the whole swingarm? what is the correct procedure? i'm a little in fear that the Machine collapses like a folding chair when i try to change the roller😆 thanks in advance for help!   Edited June 15, 2022 by Qliphoth Quote
caleb90 Posted June 15, 2022 Report Posted June 15, 2022 Thats your swingarm pivot bolt. You need to take you whole swingarm off to change your roller. Then put on a tmdesign work chain slider 1 Quote
Qliphoth Posted June 15, 2022 Author Report Posted June 15, 2022 damn😮 i inspect the small Roller with bearing further bellow first and order a new one, maybe this is the culprit with a little luck^^ Quote
caleb90 Posted June 15, 2022 Report Posted June 15, 2022 https://www.tmdesignworks.com/p-5300-atv-slide-n-guide-kit-brstock-aftermarket-swingarms-brpn-ycp-ban.aspx 1 Quote
