I was installing a tors kit on my carbs last night at work. I put the carb in a vise to hold it while i ground the idle screw thing down. Just as i walked off to get a grinder that SOB fell out of the vise. I can see no damage to it. I check the float hight at it was ok. Now here the OH $hit part. I notice on one of the carb doent have one of the small metal tubes that come out of the carb. The carb with the choke on it has it and the other doest. It looks just like the ones in the float bowl. Some one please tell me that this carb isnt screwed.
As far as the metal tube thing goes, you carb isn't screwed. Only the carb with the choke knob has it. Make sure that you get the right bowl on the right carb. Check that the hole drilled in the bowl that that metal standpipe goes into has a small jet in it. The other bowl has the hole but is blocked at the bottom. This will cause your choke to not work right if you get the bowls mixed up.
