jason.perez Posted February 5, 2021 Report Posted February 5, 2021 I’m building a new motor: t5’s 4mm long rod crank 68mm bore hjr mx hardcore port w/ case match vforce 4 reeds cool head 24cc milled domes Since I’m trying to run pump gas and 36mm pwk air strikers 3000ft was wondering what Jets I need to run just to be in the ball park Im used to the mikuni jet sizes The only needles I have are what is stock in the carbs and also what bp racing supplied me with Im sure those needles are fine all the gave me was two differnt main Jets and no pilots (and they call that a jet kit) what Jets should I order thanks in advance also, if I Plan to swap out the domes and run race gas would that change my jetting ? Quote
jason.perez Posted February 5, 2021 Author Report Posted February 5, 2021 Also forgot to ask what float height to run them at? Quote
locogato11283 Posted February 7, 2021 Report Posted February 7, 2021 The PWK will come with their own needle. Most PWK take 45-50 pilot and 155-165 main, depending on temp and elevation. Quote
jason.perez Posted February 7, 2021 Author Report Posted February 7, 2021 They gave me CEL needles I think I’ll just run then middle clip for now. I put 45 pilots and 165 mains in sure there gonna be to Rich since when I jet it it’s going to be 3000 feet I stead of where I’m located at 300 ft Quote
locogato11283 Posted February 7, 2021 Report Posted February 7, 2021 Yea, Likely have to drop to a 155-150 main for that elevation. The pilot will probably be fine. Quote
