new engine build advise needed
hoppel_1984
Hey @ all
I want to build up my engine buttom end and top end.
what is your advise for my project? You all know more about the banshee than here in germany! I do not want to build a drag bike. More an MX trail version with some road use...
Thougt about the Athena 392 top end but I not sure as I have read so much negative things here...
If your crank is trashed I did a HJR 4 mill crank, blaster pistons, stock cylinders, and FMF pipes and it was a good all purpose bike. No spacer plate I had a 2mm step cut into the domes on the head. Not an expensive build either I think it was less than $800 and half that was the crank. 4 mill crank and 66mm blaster pistons is 396 cc
Edited by devon1996
