Yaxy Posted December 14, 2003 Report Posted December 14, 2003 Has anyone installed a grease fitting into there stock Banshee swingarm on the pivot section? I can't keep bearings and the shafts from rusting and seizing after 4 months. It appears that it will easy to do just where and how many should I put in. I feel the best would be in the center, but would it end up hittign the motor or shock? Chris Quote
Holyman Posted December 14, 2003 Report Posted December 14, 2003 I will try to post some pics in images. I just did mine. Quote
holeshotkid Posted December 14, 2003 Report Posted December 14, 2003 I did the one on mine and my son's also. I tapped and installed a plug on one end of the swingarm bolt and the zerk in the other. I then drilled a hole in the middle of the bolt and lightly ground a "channel" around the bolt at the hole. I made a corresponding hole in the piviot tube that, when installed, lines up with the hole or channel that I made on the bolt. The pivot tube is hardened so you won't just drill a hole through it. I used a small grinding bit and a dremmel. Grease it a little at a time and it will make it's way to the bearings. IMHO, this should have been done by Yamaha along with a greaseable axle carrier. It's not hard to do and is well worth the time it takes. Quote
Holyman Posted December 14, 2003 Report Posted December 14, 2003 I thought about doing it that way but I wasn't close to a welder to plug up the other end of the hole and the bolt on mine is hardened. I drilled out the swingarm. I have several good pics if someone wants to see how I did it and if someone wants to post 'em that's even better. I used an angle zirk that screws into a 1/4-28 threaded hole and used a small nylon washer under the zirk to make sure I could turn it where I wanted it. It took less than 1/2 hour to do. It would probably only take 15 minutes to do now that I know what's involved. Total cost: less than $1. Quote
Yaxy Posted December 15, 2003 Author Report Posted December 15, 2003 Great ideas guys. They all sound like they would do the trick. What if I drill an inch or two hole into the bolt on both ends and put grease fittings in both ends. I could then drill a hole in bolt ends an inch or two in where the bearings are. Thus the grease would have a minumim ways to travel and would go directly onto the bearings. I would probably to have to gind a groove or put three holes in the tube to make sure the greese would go into the bearigns when the greased??? Chris Quote
Holyman Posted December 15, 2003 Report Posted December 15, 2003 Well if your bolt is like mine, you'll ruin a few drill bits before you realize that it won't drill. Send me an email and I'll show you how I did mine. Super fast only a couple tools and you don't do anything to the strength of the bolt. [email protected] Quote
