A million years ago there was someone here that cut maybe 30% more than other guys from the stock flywheel not just a little off each side of the magnets.
I’m wondering what everyone suggests for a lightened flywheel.
  • 4 weeks later...
How much weight do most take off?
I really don’t know?
It helps in “reving” quicker?
What does it do?
I have a lightened flywheel that came with a motor I was told built by hytechracing in Riverside California. Maybe he can shave one for you.
Duncan racing charges 90$ I don’t know how much they take off though.
some old posts on this:
Boonman from 2004 "The flywheel gets chucked up in a lathe and turned down. 8 ounces of weight is removed from the the outer diameter of the wheel. 4.84" is the O.D. of the wheel after machining."
BdBanshee from 2004  "I remove 8-9 ounces from the O.D. of the flywheel. Since all stock flywheels don't weigh the same, the amount varies, but the finished weight is the same.
I built a fixture that the flywheel fits on, I do not clamp on the flywheel.
2004... those kids born then are probably somebody’s parents now, or at least trying to be 🤣😂🤣
It definitely improves the throttle response. Thinking about getting one for my nephews banshee.
