Jetting help for 1st gear take off bogging
BAMF87
I’m having issues with my banshee bogging bad on 1st gear takeoffs. Once I hit higher rpms the bike will finally hit the power and and take off. What can I do to get rid of this bog Here is the setup.
HJR dune port
Stock welded crank
Chariot head 19cc domes
Chariot reeds
Shearer inframes
Keihin 28mm pwks
152 main
48 pilot
N68A needle on middle clip
Air screw 1 turn out
Idle screw 2-1/2 from touching slides
Carbs are synced
No air leaks
Elevation is 3500’ temp 80-90degrees
