Mobilemechanic Posted July 10, 2019 Report Posted July 10, 2019 What plugs do you gurus recommend 4mill aggressive dune port stock cylinder plus 7 timing 110 fuel at sea level was using b9egv cant get them anymore Quote
ClaudeMachining Posted July 10, 2019 Report Posted July 10, 2019 Br9esEnvoyé de mon SM-G965W en utilisant Tapatalk Quote
ginger Posted July 12, 2019 Report Posted July 12, 2019 standard BR8ES plugs. only reason to really change to anything else is if you switch to alky which would need a hotter plug. Quote
ClaudeMachining Posted July 13, 2019 Report Posted July 13, 2019 standard BR8ES plugs. only reason to really change to anything else is if you switch to alky which would need a hotter plug. Or race gas.Envoyé de mon SM-G965W en utilisant Tapatalk Quote
vrx46 Posted July 15, 2019 Report Posted July 15, 2019 BR8ES.. the R is for race mofo Sent from my iPhone using Tapatalk Quote
ClaudeMachining Posted July 15, 2019 Report Posted July 15, 2019 BR8ES.. the R is for race mofo Sent from my iPhone using TapatalkThough it was for "Reverse"Envoyé de mon SM-G965W en utilisant Tapatalk Quote
ginger Posted July 15, 2019 Report Posted July 15, 2019 On 7/13/2019 at 3:10 PM, ClaudeMachining said: Or race gas. Envoyé de mon SM-G965W en utilisant Tapatalk why would race gas need a hotter plug? alky is harder to ignite, hence the hotter plug. Quote
ClaudeMachining Posted July 15, 2019 Report Posted July 15, 2019 why would race gas need a hotter plug? alky is harder to ignite, hence the hotter plug. I have a better strap reading with B9 than B8 on my setup.Envoyé de mon SM-G965W en utilisant Tapatalk Quote
