PM me if interested. Prices do not reflect shipping.
Lower rear fender brackets $10
Grab bar rear fender brackets $10
Rear brake pusher and res $15
Precut vent tubing from Cascade Innovations $8 per pack
Bulk vent tubing $3 per foot, either size tube. Tubing will ship as one piece so you can cut yourself.
- 4 mm I.D. 7 mm O.D. for carburetor vents
- 3 mm I.D. 5 mm O.D for the float bowl overflow
Honda 400EX thumb throttle housing $30
- Welded additional aluminum so you can open up 39 pwk's. This will need some grinding to finish it and use properly.
OEM new right side cover $40
Lower motor tension rods with all hardware $30
Rear brake pedal $15
Dual pingle valve $60
Powder coated YFZ450R front brake calipers $40
- Need new seals and a cleaning
Pro design tether $15
Powermadd handguards $30
  - Hand guards only, no mounting hardware
Pro taper pad cover $5
  • 1 month later...
9 hours ago, Willysbanshee05 said:
Hey the rear brake master cylinder is god condition? How much is shipped to 17522?
Rear brake master cylinder is in excellent condition. Shipped to 17522 is $9.50.
  • 3 weeks later...
Honda 400EX thumb throttle housing $30 SOLD
- Welded additional aluminum so you can open up 39 pwk's. This will need some grinding to finish it and use properly. SOLD
Powermadd handguards $30 SOLD
  - Hand guards only, no mounting hardware SOLD
Pro taper pad cover $5  SOLD
Updated the list. Feel free to make offer on any parts.
Edited by PaymentPlan
  • 3 weeks later...
  • 1 month later...
Chromed spindles reamed for LSR arms $75
This is the most current list of items available.
