97 banshee leak coming from carbs and oil coming from t5 connection to silencer
shee97
Check your float height in the carbs, check bowl gasket on the carbs.  On the leaking pipes, take the silencer off, and check the seal where the stinger tube meets the silencer.  I do t remember what the T5s had for a seal there.  Some have a press-fit, some have an oring, etc.
Dont be afraid to tear into it,these things are pretty simple.
Do you have stock air box or pod filters?  Tors deleted on the stock carbs?  Might be easy to chase down the leak or might be a pain depending on how much stock garbage is on the carbs.
There is a little "valve" in the body of your carbs that have a rubber insert on them. they wear out. You need to replace the needle and seat for the fuel inlet on your carbs. Don't just do 1.... you are going to have it apart anyway do them both.
