On 2/3/2019 at 12:57 PM, Kadarius said:
Someone explain the set up as far as hp, racing, and trail
Driveline performance will hands down meet your needs as far as price and horsepower
explain the setup? a 421 requires a 4 mil stroker crank.  If you buy this setup from driveline performance, you will buy the top end, domes, and crank. you can run stock carbs and reeds on this as well but obviously the bigger carbs and better reeds will net more horsepower. after market pipes are a must on this.  you can buy the right setup for trail or drag racing.
http://drivelineperformance.com/yamaha/banshee/cylinder-kits/
