Take a bulb out and test it on your car battery. If indeed they are good, there is a red wire in the switch that I have seen disconnect itself from its solder joint. I they are blown, test the voltage at the headlight  socket with a multimeter set to AC. Also look to be sure the regulator is bolted down tight to clean bare metal.
